Author Topic: noob question: function generators  (Read 3678 times)
Offline outofstepperTopic starter
« on: June 07, 2012, 02:10:24 pm »
Ok, this question might get a lot of eyes rolling and/or tears from laughter.. but here
we go..
Entry-level FG ($$$) vs. 555-based shoebox FG (~free)
used for learning / eventually debugging broken stuff.
So i won't be getting the freq range / stability / accuracy / ease-of-use of a pro unit.. understood..
but what I'm not quite so sure about is if I'm starting out with both hands tied behind my back
because of any (obvious?) limitations I might not be aware of.
Thoughts?
and thanks!
Tony
Offline Bored@Work
Re: noob question: function generators
« Reply #1 on: June 07, 2012, 02:21:11 pm »
What do you have to lose? If you think the free 555 shoebox will do, then start with it? While using it you can save more money to buy a real generator, and learn things the hard way. Aka the school of hard knocks.
Offline Lightages
  • Canadian po
« Reply #2 on: June 07, 2012, 02:40:21 pm »
As long as you can get a decent sine wave out of the shoebox parts then I second the post above.
Offline T4P
  • Country: sg
    • T4P
« Reply #3 on: June 07, 2012, 03:28:52 pm »
One should simply start off with building his/her own "555" based Sig Gen, thy learns more that way
Offline hlavac
  • Country: cz
« Reply #4 on: June 07, 2012, 10:32:53 pm »
How about something designed for the job, like XR2206? Do they still make them? Or are there any modern alternatives?
In fact, as a pure electronics hobbyist, I'm missing a function gen too! Maybe we could design one together? :)
Good enough is the enemy of the best.
Offline MikeK
« Reply #5 on: June 07, 2012, 10:41:49 pm »
Before I bought my Instek I was considering this: http://www.electronics-diy.com/store.php?sel=kits&sub=function_generator
Only $40.
Offline Barryg41
« Reply #6 on: June 07, 2012, 10:56:16 pm »
I ordered and put this kit together to mess around till I decide on a proper FG.
http://www.kitsusa.net/phpstore/html/Elenco-FG-500K-1MHz-Function-Generator-Kit-5974.html
Works for me right now!
« Reply #7 on: June 08, 2012, 01:20:08 pm »
Thanks guys.
That kit from electronics-DIY looks interesting and I'll likely pick it up.
 -- two minor points though (not complaining!), the freq range selector
is pcb mount dip switch so if I wanted to put this in a nice case I'd have to find a selector switch
(I assume only 1 of the four pins goes high to select).  Second, the freq counter kit is nice too but
resolution in 10Mhz steps.
Beggers being choosers?  Maybe.  ;D
Thanks again!
Tony
Offline caroper
    • Take your PIC
« Reply #8 on: June 09, 2012, 08:47:41 am »
Thanks guys.
Before you do take a look at this one:
http://www.changpuak.ch/electronics/FG2206.php
I am not sure if there is a kit, but it is very well documented.
Look under Project Details on the Right below the clock.
Cheers
Chris
« Last Edit: June 09, 2012, 09:22:02 am by caroper »
