Author Topic: How do true RMS digital multi meters work?  (Read 3507 times)
Offline alanbTopic starter
« on: December 19, 2012, 12:34:57 pm »
My guess would be that for each cycle there would be a series of measurements that would be squared, averaged and then square rooted. Am I correct?
If so on a decent meter how many samples per cycle would be taken on say a 50Hz input?
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
Re: How do true RMS digital multi meters work?
« Reply #1 on: December 19, 2012, 01:57:31 pm »
Most meters use a dedicated IC such as Analog Devices' AD536A or AD736.
Other use analog multipliers.
If the instrument is DSP based, then the DSP can do the mathematics, and compute the RSM value directly starting from the A-D sampled values.
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
Offline Wytnucls
« Reply #2 on: December 19, 2012, 02:34:18 pm »
Here is the PDF datasheet for the AD636, with a fair amount of information about the principle of operation:
« Reply #3 on: December 19, 2012, 03:11:28 pm »
Thank you ciccio and Wytnucls for the info.
Offline blackdog
  • Please stop pushing bullshit...
« Reply #4 on: December 19, 2012, 03:25:28 pm »
Linear Technology app. note...
www.linear.com/docs/24931
www.linear.com/docs/4117
Kind regarts,
Blackdog
Necessity is not an established fact, but an interpretation.
« Reply #5 on: December 19, 2012, 03:54:56 pm »
The last page of this application note, the good the bad and the ugly..... is fascinating.
Thanks blackdog.
