Could I just make my own current probe?
Quote from: ali6x944 on September 06, 2016, 08:04:08 amCould I just make my own current probe?You can, I did for my first one but always yearned for a proper one.I used a small CT from an old PC PSU and roughly calibrated it using a borrowed current probe with a resistor across its output. Trouble was there was no way to measure anything without breaking the circuit and soldering a wire through the hole in the CT. Worked fine up to a few KHz.How I have a couple of P6021's, AC only, 15A max and 60 MHz rated.
The iProbe 520 is very nice. But as said before: list your requirements first.
Quote from: tautech on September 06, 2016, 08:56:03 amQuote from: ali6x944 on September 06, 2016, 08:04:08 amCould I just make my own current probe?You can, I did for my first one but always yearned for a proper one.I used a small CT from an old PC PSU and roughly calibrated it using a borrowed current probe with a resistor across its output. Trouble was there was no way to measure anything without breaking the circuit and soldering a wire through the hole in the CT. Worked fine up to a few KHz.How I have a couple of P6021's, AC only, 15A max and 60 MHz rated. it is a good idea but dose it measure low frequency ac
Quote from: Ice-Tea on September 06, 2016, 08:59:14 amThe iProbe 520 is very nice. But as said before: list your requirements first.a frequency of 100 MHz is fineAttenuation ratio: x10measure DC as well as AC Dynamic range i really did understand what is it , could u explain briefly please.
...ali6x944 is a beginner and he can't give especifications of what he need.
Quote from: oldway on September 07, 2016, 10:48:50 am...ali6x944 is a beginner and he can't give especifications of what he need.Which is why he is posting in the beginners section. To get advice and to learn. Probably not to be laughed at.
A 100 Mhz current probe for doing some repairs on a couple of SMPS and other ac appliances Are you kidding ? Did you not understand that 100Mhz and attenuation x10 are not especifications of a current probe but are especifications of a voltage oscilloscope probe ?ali6x944 is a beginner and he can't give especifications of what he need.You don't even need a current probe to repair SMPS...
Quote from: ali6x944 on September 07, 2016, 07:09:19 amQuote from: Ice-Tea on September 06, 2016, 08:59:14 amThe iProbe 520 is very nice. But as said before: list your requirements first.a frequency of 100 MHz is fineAttenuation ratio: x10measure DC as well as AC Dynamic range i really did understand what is it , could u explain briefly please.
Wait it isn't the same type of attenuation as in voltage probes?
