If the adjustable adapter is what is in the picture, these adapters are not regulated (almost sure, of course I have not seen the internals of yours, but I have seen many not regulated adapters with this appearence). Often they give more voltage than marked, specially if the load is low (easily 25% or more excess).
If the other adapter is regulated and gives exactly 7.5, this can be important, as some devices with a 7.4 volt battery (2 cells) can need some extra voltage to work (7.8 to 9V, thats depend on device), due to the circuitry in the car, (in your case). You have to check what is the nominal voltage needed by the car, an check also the output voltages of adapters, probably 7.5 volst is too near the limit.
Be very careful with these adjustable adapters, is very easy to give your device an overvoltage or inverse polarity. If I use them, I cover the switches with tape to block their position.
We need more details to find the problem.
