Silver in a band used as multiplier indicates x0.01.
Does 0.14 ohm +/-2% 20ppm/K and 0.12 ohm +/-2% 20ppm/K make sense?
Yeah silver for 0.01x for sure,
The 52silv21 reads as 0.20 or 0.27, it moves a lot. There r 2 in parallel are between negative of a 4pin rectifier, and GND-ref of the tank cap, for almost everything else HS on a CX600W SMPS.
the 52sil41 started at 0.60 and quickly dropped to 0.02 and shorting my BM869 gave 0.03 atm.
Could they be inductors ? There are beefy NTC thermistors or something right before the main tank cap, IDK maybe it's more inrush current limiting ?
