The ferrite - pi filter EMI filter is right off the datasheet but why would I care about really high frequency EMI in an audio output device?
Quote from: tapirath on June 09, 2023, 09:47:40 amThe ferrite - pi filter EMI filter is right off the datasheet but why would I care about really high frequency EMI in an audio output device?There are at least two reasons:1) it reduces audio noises.2) it minimize RF effect on output amplifier and as result minimize audio distortions and unwanted audio interferences due to RF signal mixing on semiconductor elements such as transistors and diodes which is used in audio circuitProbably you have hear annoying buzzing noise when a cell phone is working near chinese audio amplifier. This is because chinese audio amplifier lacks of such RF filters and shielding... As you can see, the result is very well audible at audio frequencies, despite the fact that the operating frequency of a cell phone is 900 MHz. This is due to a mixing effect of RF interferences on a semiconductor elements, such as diodes and transistors which are used in audio circuit.
Let me rephrase: why duplicate the whole circuit? Your headphones don't give a hoot if they're supplied from one capacitor plus diverse or from two.Just connect L+R together in the connector and only build half of your current thing.
