Author Topic: Find That Connector!  (Read 2771 times)
Offline ciikucliTopic starter
« on: September 19, 2012, 11:15:22 pm »
I remember a circular wire connector that screwed on to a threaded female jack. Can anyone point out that connector? Or another with a locking capability so it doesn't come unplugged?
Offline robrenz
  • Real Machinist, Wannabe EE
Re: Find That Connector!
« Reply #1 on: September 19, 2012, 11:54:00 pm »
You can't expect any help when you give no details of what you are talking about.  :(
Offline olsenn
« Reply #2 on: September 20, 2012, 12:53:04 am »
It's called a banana socket!
Offline nanofrog
« Reply #3 on: September 20, 2012, 03:10:04 am »
Not sure what you're asking (good description would really help, pics even better), but if it's something like a DIN locking connector (M5 ... 7/8"), you might want to take a look at Binder's connector products (http://www.binder-usa.com/).
« Reply #4 on: September 20, 2012, 04:57:34 am »
I don't have much to give, but I was looking for a cable connector capable of transmitting a digital signal both ways in order to interface with a microcontroller. It's going to be attached to a moving object. It has to disconnect, and I though I remembered a connector that either locked to the socket, or had a screw type connector. Banana sockets are not quite right, as I want the male end to have a connector for easy deattachment/reattachment.
Thanks
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #5 on: September 20, 2012, 05:44:09 am »
Something like this? http://uk.farnell.com/pro-signal/psg01590/socket-multipole-4way/dp/1280756
You can get them in 2/3/4/5/6 pin versions at least. Generic and cheap, screw locking, strain relief etc. Panel mount, or in-line.
Offline AndyC_772
« Reply #6 on: September 20, 2012, 09:21:56 am »
Have a browse of www.toby.co.uk - they're guaranteed to have something suitable.
« Reply #7 on: September 27, 2012, 06:25:19 pm »
Thanks you guys. One of those should be suitable!
