I have just finished evaluating a Mastech linear power supply. I had to get hold of high power resistors to load it down to maximum and I was surprised it did better than its specification; it also did not blow. I don't have time to post the pics and raw data, but if you're looking for a great linear PSU for under $100, Mastech is very competitive, for this model:
Load regulation: maximum load, 3A, 30Vdc, ripple was in the microvolt
under lower voltages it was fairly constant at under 1mV, down to 0.1Vdc, a bit concerning but good, when using it to drive low voltage circuits
Did not test line regulation
Power draw quiescent was 8W, at maximum load it drew 140W
CONS:
The amp meter is quite accurate, the voltmeter is not. This is because it measures Vdc out including the internal resistance drop of the PSU, so under load the voltmeter reading is off as high as 10%.
You can recalibrate both meters, it has its own adjustments screws under the meters, and is not mentioned in the manuals. However, the internal resistance wont' change the accuracy of the voltmeter.
The voltmeter is non-linear, and even with zero load there is a 1-0.5% error reading 0-30V.
The voltmeter is most accurate the lower the loads are. its not a problem driving modern circuit designs that draw in the mA, but if you're near 1A, its best to get a separate DMM to monitor the supply.
The fan is always on. Its unnecessary under 1A loads, but it would be best if it had a small thermal cutoff switch since it is noisy. It is definitely needed once 1A loads are used, and the unit starts to get hot internally.
See discussion here:
https://www.eevblog.com/forum/index.php?topic=683.15My unit:
The Hi/Lo switch doubles the current output for the current current knob setting. A strange switch but the main advantage is that the total power consumption of the whole PSU is lower slightly if this switch is LO for the same output volt-amps, in other words if you output 1A at 30V with this switch at LO, the power consumption is lower that if you switch it to HI and still output 1A, 30V.
So default, leave it at LO until the amps provided are no longer sufficient.
The fine adjustment is terrific! You can adjust millivolts and milliamps with easy stable precision.
The lowest price Mastech is $50, its a steal.
If you are in the US, you might look over some of the Mastech power supplies at
http://www.mastechpowersupply.com/
They have been happy to send me schematics of power supplies I've been
interested in. Have the schematic is important to me, because it gives me a
decent chance to repair the supply if something goes wrong. The Mastech
ones I've looked at are pretty much all off the shelf parts, quite repairable.
I have a power supply from Circuit Specialists:
http://www.circuitspecialists.com/level.itml/icOid/8613
that I got off of Ebay, and I've been quite happy with it as well.
Scott
