Just got a new Hantek cc-65 current clamp and thought I'd compare its readings against an RMS Fluke DMM clamp meter I also have. I used battery charger leads connected to a battery for the test, the Fluke gave me a reading of 0.9-1A and the Hantek, which was set to the 1mv/10ma, gave an RMS on the scope of 197mv, which I imagine equates to 1.97A. Both the Hantek and the Fluke were zeroed out prior to clamping, though with the Hantek woudn't budge from a min value of about -8mv.
Not sure if I'm missing something, but I expected those values to be about the same, not a whole amp different.
Any thoughts?
Hi there,
Some of these clamps can be very sensitive, very sensitive. From what I have seen, this requires some extra care when making a measurement.
I have one clamp that is so sensitive that it detects the small magnetic field of the earth.
Since the clamp has a field sensing orientation associated with it, if you even twist the clamp the reading will change. This means when I zero out the clamp I have to hold it in the exact same orientation when I clamp onto the wire to be measured, otherwise the zero will change even before the measurement is made. I cannot even twist the clamp a little, because then it senses the magnetic field of the earth a little differently and that messes up the reading of the current in the wire.
So one thing you can try is to hold the clamp steady while you zero it out, and then do not rotate it in any direction as you clamp in on the wire to take the reading. This requires orientating the clamp into the same plane as it will be when you finally clamp it on the wire when you zero it out. A translational movement does not seem to matter unless there are other magnetic fields close by like a big magnet or perhaps some metal that has been magnetized.
This works with mine, maybe with yours too. I was looking to measure currents as low as 10ma.
I did the same thing you did, which was to check the clamp with another reliable meter, except I used a regular wired meter to compare, not another clamp. If the current measurements are the same or close I assume that the clamp works ok.
