I have an idea about useability of DC power supply controls. Will typical hobbyist user be satisfied with supply with no digital displays. Just few leds and knobs?
Consider the panel with banana outputs, red led indicating constant current mode, green led indicating constant voltage mode, one knob for 10 fixed voltages: 1.200V, 1.500, 2.500, 3.300, 5.000, 6.300, 9.000, 12.000, 15.000, 24.000V. And one current limit knob for 10 fixed limits: 0.1mA, 0.5mA, 1, 5, 10, 20, 50, 100, 500, 1A.
The numbers are painted on panel for each knob. It will take very little space, will give feel of repeatability and precision. But resolution is coarse.
My reasoning for such UI is that most of the functionality needed from PSU is a constant voltage for some design, where rails are long decided upon. And current limits are also decided and clearly belong to certain damage levels for different circuits. For example LED will never need more than 20 mA. Or relay will never need more than 100mA, etc.
Any fine measurements can be done once with external multimeters. Users need repeatabilty, low noise and clear function more than resolution.
What do you think? Did you ever need some specific voltages for PSU other than listed ?
