Range: 3W - 30W///
Setting Range: 0 - 30.6W
It seems that this DC load cannot do <3W properly due to limited mechanism of CP control. In video it can be seen that from 1.5-2W DC load almost manages to work, but with all CP settings
current is very unstable. IMO CP mode is implemented indirectly via digital control of CC mode with disadvantage of slow performance and erratic behaviour (i.e., check current*voltage value; change CC value; check current*voltage value; change CC value; ...). The point is that power is not directly controlled.
This is similar to how Rigol DL3000 works in CP mode, current is not exactly stable with 1.5W at 1.4V input (but it can work to ~100mW or less).
Very high end DC loads have better performance in CP mode (some even have hardware or analog CP mode, which works much better).
That would just be terrible because it allows me to enter 1mW…
1mW setting resolution is likely there just to match readback resolution, not that it is usable.
