Author Topic: soldering  (Read 2331 times)
Offline abdullahsebaTopic starter
soldering
« on: September 02, 2014, 01:05:54 pm »
can you use a hot air iron for through hole soldering?
This is my right hand this is my wrong hand
Offline sleemanj
  • Professional tightwad.
Re: soldering
« Reply #1 on: September 02, 2014, 01:35:57 pm »
No.
Offline KJDS
    • my website holding page
Re: soldering
« Reply #2 on: September 02, 2014, 01:40:46 pm »
No.
Yes.
Someone skilled enough with a hot air gun can solder anything that can be done with an iron. It's just a lot more difficult than using an iron.
Offline d3javu
  • Country: my
Re: soldering
« Reply #3 on: September 02, 2014, 02:01:46 pm »
If you have a dead or used pcb and a blower, give it a try, see for yourself how easy or hard it is. Otherwise, better spend it on a solder station.
Offline Terabyte2007
  • It is purpose that created us... That defines us..
Re: soldering
« Reply #4 on: September 02, 2014, 02:15:57 pm »
Yes, but there are easier ways. If you have a Re-Work station with an adjustable temp and pump, you can use a small tip and direct the right amount of heat and airflow in the area you need to extract or solder a through hole point. However, using a solder iron with the appropriate tip will yield better results.
Eric Haney, MCSE, EE, DMC-D
Electronics Designer, Prototype Builder
Re: soldering
« Reply #5 on: September 03, 2014, 09:13:03 am »
thank you
can you fit a iron on the ATTEN AT 858D+ instead of the hot air piece
Offline sleemanj
Re: soldering
« Reply #6 on: September 03, 2014, 10:09:30 am »
thank you
No
to keep the pedants happy, no, not unless you want to do some major hacking.  The hot air piece element runs at main voltage from memory, while 936 style handles run at lower voltages.  It's hard wired, while handles are socketed.  The temperature sense method may (likely is) different, the calibration and control method for hot air and iron would be most likely totally different...
