I normally use command-line tools like
awk and
gnuplot for such things, and was going to write an answer on how to do it, but then I vaguely recalled that LTspice's plot view ought to have an expression editor. (I'm not even sure if I've used LTspice except for some experiments, however, so the following is basically all I know; hope it helps.)
Looking at
LTspice Tips at Digikey, you can add a new trace to the plot in the WaveForm Viewer, and change its expression to
V/I (assuming the voltage trace is named
V and the current trace
I ). So, you should be able to do this in LTspice WaveForm Viewer.
