I have a pair of buck switching converters in a circuit, the LM2673 and the LM2679. However, the LM2679 is being used in a buck-boost configuration as shown in this app note below, AN-1157, and I'm converting a positive voltage to -10 volts. The LM2673 is being used to convert a DC voltage down to 5 volts. You can see my circuit below.
So far, I've tested it with a bench power supply supplying 3 amps, outputting at 12 volts and 15 volts. However, when a load is connected to the output, the power board and load seems to be drawing more current than 3 amps, bringing the bench supply to current-limiting mode. The work around I've found is to change out the current-adjust resistors on the regulators (increase them to limit the current to lower values, 1 amp and 3 amps). Changing out the resistors seem to work that way.
I think the problem is that the bench supply can't supply enough current on start-up. I want to try and use a 20 V (4.5 amps) supply, but do the regulators have a limitation on the output-input voltage difference? The ICs are rated for 40 volts input max, but with a 20 volt supply, the voltage difference would be 15 volts and 30 volts respectively (for positive and negative voltages). Would this be within safe operation?
https://www.ti.com/lit/ds/symlink/lm2673.pdfhttps://www.ti.com/lit/ds/symlink/lm2679.pdfhttps://www.ti.com/lit/an/snva022e/snva022e.pdf?ts=1598635634497&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FLM2679EDIT: Using a shunt resistor (1-ohm power resistor), it appears that the power supply board is drawing 4 amps upon startup. I found a 12 volt 5 amp supply, but is it safe to use it in place of the bench power supply, or would it be better to limit via the current limiting resistors for the ICs?
