Author Topic: Single ended signal on PCB  (Read 584 times)
Offline Vcky_electroTopic starter
  • Country: in
« on: June 13, 2019, 12:19:39 pm »
I have designed board, in that due to board room limitation we cant achieve 50ohms impedance for single end signal. 60ohms is possible in that design, so what would happen if we use 60ohm impedance trace instead of 50ohm trace..
Regards,
Vicky
Offline Raj
  • Country: in
  • Self taught, experimenter, noob(ish)
Re: Single ended signal on PCB
« Reply #1 on: June 14, 2019, 05:43:02 pm »
you'll have to change your termination method, that's it
