Author Topic: Software to print Analog Meter Scale  (Read 11248 times)
Offline tanveerriaz
  • Country: pk
Re: Software to print Analog Meter Scale
« Reply #25 on: December 17, 2023, 06:25:56 pm »
Offline BeetleJuice
  • Country: gr
« Reply #26 on: September 12, 2024, 07:30:46 pm »
https://soulmare.github.io/scale_master/
this program is amazing but cant find how to save my work ! any ideas?
Offline Poroit
« Reply #27 on: September 13, 2024, 07:54:13 am »
What are the existing scales on your meters?
If the existing divisions match your project then you can reuse the dials.
I have done this heaps of times.
Carefully scrape off the existing numbers with a razor blade...don't press to hard as you do not want to damage the white paint beneath the numerals.
Buy your self a sheet of Letraset or similar numbers with the correct font size and apply the appropriate numerals.
Spray the dial with the Letraset sealer.
Offline tooki
« Reply #28 on: September 13, 2024, 10:05:00 am »
Download > SVG Image
As long as you don’t edit the SVG in another program, then it reopens properly in Scale Master.
Offline BeetleJuice
  • Country: gr
« Reply #29 on: September 13, 2024, 11:09:05 am »
JESUS ! it keeps all my work in the svg file? its like a save?
thank you!
Offline tooki
« Reply #30 on: September 13, 2024, 11:15:46 am »
I think so. I used it last spring to make a meter scale and I think that’s how it worked.
(I then imported the SVG into Inkscape to make some changes to the typography, etc. But be sure to save a copy because once you edit the SVG in another program, the original data is lost for Scale Master.)
Online SteveThackery
« Reply #31 on: September 13, 2024, 08:44:42 pm »
I've made several meter scales. I use Microsoft Visio, which is a great diagramming tool and good for the job. I print onto matt white photo paper, which can then be glued to the original dial.
