Author Topic: Gate Drive Transformer Reset at 20kHz+  (Read 3623 times)
Offline TimeTopic starter
« on: August 13, 2014, 10:34:56 pm »
What are some common circuit topologies for handling gate drive transformer reset at 20 kHz (the high end of audio)?
I have commonly seen a combination of zener's and regular diodes but how to spec. the parameters is not completely.
Anyone have some experience in this area?
-Time
Online T3sl4co1l
    • Seven Transistor Labs
Re: Gate Drive Transformer Reset at 20kHz+
« Reply #1 on: August 14, 2014, 02:01:39 am »
Reset?
What application?
Seven Transistor Labs, LLC
« Reply #2 on: August 14, 2014, 02:48:40 pm »
Using a gate drive transformer (1:1) to provide an isolated drive signal to a power electronics device, like a power MOSFET.  What are some common techniques for dealing with the reset of the transformer?
-Time
Offline Marco
« Reply #3 on: August 14, 2014, 03:17:39 pm »
You just use a near 50% duty cycle, which is not to say you have to drive the MOSFET at 50% duty cycle ... but you'll need to get tricky to avoid it.
http://www.irf.com/technical-info/appnotes/an-950.pdf
« Reply #4 on: August 14, 2014, 03:35:11 pm »
Unfortunately I want to be more in the 25% duty cycle range.  I know I have seen some clever circuits involving a zener diode combine with a normal diode in parallel with the primary.  I was just curious as to how this works and if anyone has experience with them.
-Time
Offline David Hess
  • DavidH
« Reply #5 on: August 14, 2014, 04:15:06 pm »
Look up how forward converters reset their transformer.  They generally use a separate reset winding but that is not necessary.
Offline Marco
« Reply #6 on: August 14, 2014, 05:03:54 pm »
No experience, but this paper has a couple versions :
http://eprints.qut.edu.au/63591/1/fetdrvr-t.pdf
Like it notes though, these kind of circuits have limited high time because the gate isn't actively driven and leakage will pull it down. That's why they decided to use a circuit with a separate isolated power supply in the end.
Online T3sl4co1l
« Reply #7 on: August 14, 2014, 11:16:57 pm »
25% range, for one channel, or is this driving two complementary sides, or what?!
While you can fully abstract this problem by hiding information from us and leaving it in only the most general terms, you are guaranteed to end up with a wasteful, expensive, poorly performing design.  Some circuits are more suitable than others.
You may not even want a transformer at all, but unless you tell us something about it, we can't help.
« Reply #8 on: August 16, 2014, 06:07:29 am »
Ok.  I want to drive a silicon power mosfet with a gate source capacitance of a few nF through a pulse transformer at 20 kHz to create pulses via a high side switching configuration.  No complementary sides, just one device that is creating pulses.  The duty cycle might change but it will always be low, 25% at the most.  I am just brainstorming options at this point and more or less trying to figure out what may be considered the conventional approach.
-Time
Offline Dago
    • Electronics blog about whatever I happen to build!
« Reply #9 on: August 16, 2014, 06:37:47 am »
I'd say just forget about gate drive transformers in an application like this and use an isolated gate driver like ADuM7234: http://www.analog.com/static/imported-files/data_sheets/ADuM7234.pdf or traditional http://www.irf.com/product-info/datasheets/data/ir2110.pdf
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
