I'm working on a project involving a microcontroller where I need it to consume no power when off, and then when the button SW1 is pressed the power switches on and stays on until the microcontroller sends the OFF signal. So far I have this. VCC is the power that comes from the battery, and V+ is the power going to the rest of the circuit (after having typed that, I've realized it'd probably make more sense to have those two labels switched, but I digress)
Because the microcontroller is going to have a decoupling capacitor next to the power pin, I thought that I should put a diode after the toggle section so that the latching transistor will shut off properly and not be kept going by charge coming from the capacitor, and to generally isolate the toggle section from the rest of the circuit. Will this work as I'm thinking, and is the diode even necessary?
Also, any feedback on the design in general would be appreciated.
