Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
How can I reproduce this failure?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: How can I reproduce this failure? (Read 569 times)
Chabscan
Newbie
Country:
on:
April 05, 2024, 05:19:37 pm »
Hello.
I am checking an electronic cover for a wiper motor. The relay driver / voltage regulator 2550klp is completely blown at its input.
I now am trying to replicate this in my table but it seems just cranking up the supply does not do it, it works normally at 13.5 V
What could actually have happened in the vehicle to specifically damage this component?
Thanks a lot in advance.
Logged
floobydust
Super Contributor
Country:
Re: How can I reproduce this failure?
Reply #1 on:
April 05, 2024, 05:37:21 pm »
Where is the IC's datasheet, and rest of the schematic.
Inputs from the wand are 12V? CTRL goes to relay driver transistors?
There are many reasons for the IC to burn up.
Logged
mikerj
Super Contributor
Country:
Reply #2 on:
April 05, 2024, 05:43:53 pm »
The Allegro 2550 example circuit shows a diode in the VBB supply, presumably for reverse polarity protection, and your schematic doesn't include this, so perhaps the battery was connected backwards (quite common in the automotive world).
Logged
BennoG
Regular Contributor
Country:
Reply #3 on:
April 05, 2024, 06:14:37 pm »
In a car the voltage can go up to 14V when a normal battery is connected.
If there is no battery connected or one that is almost dead the voltage can go up to 18v
But my guess is reverse voltage connected.
Benno
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
