Hi, new user here. As the subject line says, looking for help with a soft starter for a project. Not to worry, I'm no bot and I'm not here to spread delicious breakfast meat around the forum, this is a legitimate request for assistance.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
My problem is this - I am working on an automotive project that will require that I either move the air conditioner to a non-standard location or do without. The only thing I'm going to have room for on the front of the engine is a high output alternator slung low on the passenger side as the rest of the area between the engine and radiator will be taken up with a couple of turbochargers and the required piping to run them. This is the compressor I plan to use, and the link goes to a page where it shows a compressor for sale. I've also already verified that this compressor will provide enough cooling to keep me happy. I just need to work out this one problem.
https://www.vmacs.net/products/12vdc-electric-ac-compressor-for-e-6100-e-9725-units-rd-2-7777-0pMy problem is an AC compressor cycles regularly, and this particular one pulls 100 amps to operate. As you can imagine, a 100 amp load on a 12V system can play some havoc with everything else on there. The other thing, I'm not sure if there will be an inrush current involved on this. I've been searching all over the place, and every time inrush current is discussed it's always on AC stuff, not DC.
So, what I'd like to know is, do I have to worry about a current inrush problem here? And, can anyone recommend a soft starter for this unit that works automatically and isn't huge? I don't need anything fancy, just something that will start the compressor without blowing a fuse or causing the rest of my system to take a dump. A 1-2 second ramp-up speed would probably work fine for this, and I'm not concerned with shut-down as the battery should be able to absorb the load. Of course, if anyone can recommend a 12VDC R134a compressor that pulls less juice while providing at least 12K BTU of cooling power I'm all ears. I've been researching this issue for quite a while and so far this has been my best find.
Thanks in advance for any assistance.
