I am working on a gateway device that translates TTL to CAN & RS485/modbus frames. Software wise I have it all sorted but I also wanted to implement basic hardware protection.
Drivers:
CAN - SN65HVD230DR
RS485 - THVD1406DR
TTL - ESP32
Input voltage to the board is 48V with few step down DC/DC converters so I want to protect the circuit also against mistake in wiring on top of other failure related OV/OC conditions. Reverse polarity is addressed via Shottky diode but now I want also to protect bus drivers. I did not go for opto isolation and wanted to start with basic "minimum".
My plan is to use Resettable Fuses - PPTC on each line CL, CH, A+, B-, RX, TX for a total of 6 for OCP with trip current of 300mA/hold 100mA and 60VDC.
Then "crowbar" circuit for OVP:
>SZNUP2105LT1G one for CAN, CH, CL tied to GND
>SZNUP2105LT1G one for RS485, A+, B- tied to GND
>2x TISP4015L1AJR-S, one for TX and one for RX lines tied to GND.
Question 1: SZNUP2105LT1G is specificaly for CAN but looking at the datasheet no reason it wouldn't work for RS485. Brekadown voltage appears to conform with both. Do I miss something? Same part, simplier BOM.
Question 2: TTL operates at lower voltages, and breakdown voltage of SZNUP2105LT1G of 26-32V to my liking seems to be too far from the TTL levels. TISP4015L1AJR has breakover of 15V. Is that still too far off or acceptable? TVS diode vs. thyristor I don't consider a factor here, both parts are for digital communication so speed should not be a concern. CAN is 500k, RS485 is 9600 and TTL is 9600.
Thanks in advance.
Regards,
M
