Loading [MathJax]/extensions/Safe.js
Author Topic: Battery Discharging Circuit  (Read 4596 times)
Offline vincentleestTopic starter
« on: October 30, 2010, 07:36:08 pm »
I'm working on a project that requires me to discharge a battery from 12V to 10V with a constant current of 14A.
I read about this thread and took batee's design and modified it for a bit.
https://www.eevblog.com/forum/index.php?topic=1219.msg15720
Q6,7,8  are IRF3910
Q5 is ZXT450
I am not very confident about my changes, please point out my mistakes and give me some comments.
Thank you!
Offline qno
Re: Battery Discharging Circuit
« Reply #1 on: October 30, 2010, 08:26:14 pm »
you need to replace the resistors of 1 k by a resistor of 0.15 ohms.
You need to cool the IRF3910 on a very large heatsink that can dissipate 170 Watt.
Why spend money I don't have on things I don't need to impress people I don't like?
« Reply #2 on: October 30, 2010, 09:38:46 pm »
did you mean the 3 parallel resistors connected to the transistors? or some other resistors?
and thank you for you help =)
« Last Edit: October 31, 2010, 12:35:04 am by vincentleest »
Offline qno
« Reply #3 on: November 01, 2010, 12:48:23 pm »
The 3 1k in the sources of the Fets.
With a source resistor of 1k no more than 12 mA can flow in the FETs.
Offline Feanor
« Reply #4 on: November 02, 2010, 07:49:49 am »
I would just like to double check how you got a resistor value of .15ohm. I got 0.333ohm. Where dd I go wrong?
14 amps / 3 = 4.667A in each source resistor.
The output of the 1k/820 ohm voltage divider will settle to 0.7V greater than Vout.
So the input needs to be 0.7*1820/820 = 1.553V. This voltage is the IR drop across one source resistor.
4.667A flowing through the source resistor gives us 4.667*R = 1.553V
R = 1.553/4.667 = 0.3327ohm ~=0.333ohm = 3X1 ohm resistors in parallel.
If I made a mistake please point it out.
Offline qno
« Reply #5 on: November 02, 2010, 08:34:42 am »
The capacitor is series with the 820 ohm cannot pass DC.
It is not a voltage divider.
This is a damper or filter.
The rest of our analysis is OK.
« Last Edit: November 02, 2010, 08:36:17 am by qno »
Offline Feanor
« Reply #6 on: November 02, 2010, 08:46:10 am »
Ahh ha I see! I was miss reading the schematic! Thought there was a connection where there was not one. Thank you.
