Author Topic: Four pad crystals  (Read 1892 times)
Offline EmilTopic starter
  • Country: no
    • ZeptoBit
Four pad crystals
« on: March 15, 2017, 11:40:23 am »
I'm planning to use a four pad quartz crystal. The datasheet shows pad 1 and 3 to be connected to the crystal. Pad 2 and 4 are not shown to be connected to anything, but it doesn't explicitly say NC either.
What should I do with pad 2 and 4?
1. Leave unconnected.
2. Connect to gnd.
3. Connect 1-4 and 2-3 together (saves space by not needing to route a trace around the pad)
The part is ABM10-167-12.000MHz-T3, datasheet: http://www.mouser.com/ds/2/3/ABM10-167-12.000MHz-962396.pdf
Offline Rerouter
Re: Four pad crystals
« Reply #1 on: March 15, 2017, 11:54:34 am »
In general i connect them to the same ground as the crystal capacitors, and have that ground trace run right back to the oscillator ground pin before it meets the ground plane.
The following users thanked this post: Emil
Offline ataradov
    • Personal site
« Reply #2 on: March 15, 2017, 06:59:31 pm »
I've seen justifications for both 1 and 2. But don't do 3, for sure, since in some cases top metal can is connected to one of those unconnected pins, and you will short your crystal.
Alex
Online wraper
  • Country: lv
« Reply #3 on: March 15, 2017, 07:28:32 pm »
Actually not some cases but everything I've seen has those pads connected to the metal cover and internal metallization. It's strange that datasheet does not say anything about those pads.
First random datasheet which I found for similar crystal http://www.ndk.com/images/products/catalog/c_NX2520SA-STD-CSW-4_e.pdf (says should be connected to GND)
« Last Edit: March 15, 2017, 07:31:47 pm by wraper »
Offline Kasper
« Reply #4 on: June 26, 2024, 11:30:19 pm »
I just had the same question about this same part.  Asked google first, found this, then checked Abracon's website for extra info.
'Package drawing' on their website show 2 and 4 should be grounded.  It also shows a recommended land pattern that is slightly smaller.
Online Benta
« Reply #5 on: June 26, 2024, 11:36:42 pm »
My feeling is that this was solved 7+ years ago...
