I reckon I should be able to pick up a Fluke 179 for similar money, do you think the Fluke would be any better? The only thing I like about Fluke is that it has the name which means it'll hold its value better and just generally give the owner a warm fuzzy feeling ;0)
Whether a 179 would be better than any other given meter is probably a personal decision. I can tell you why I very much appreciate the warm, fuzzy feeling using a Fluke gives me, but it may not make much sense to you.
I frequently work with equipment voltages of many hundred volts, and have once too many experienced what a dead short on a powerful DC supply rail means (big boom, sometimes involving metal shrapnel from your tool and/or instantaneous spot welds!)
Finally had enough of that, and today I absolutely refuse to use any piece of test gear for a situation like this, unless I am 100% unconditionally certain it
*will* go the distance. A Fluke meter like the 179 will have multiple, independently verified tests of its CAT rating, provided by UL, VDE, TÜV and CSA.
The meter you link claims CAT-IV protection to 1000V, which sounds impressive. Until, that is, you realize the datasheet doesn't list any independent test laboratories, who are prepared to back up this claim. Checking Brymen's homepage it seems they only bother seeking certification from UL.
I'll start considering other brands for my high voltage work, once Fluke meters fall me in the trust I bestow them. Not to mention I also know for how long a new Fluke meter will last: About as long as either Fluke or I am alive, as many of Fluke's models carries a lifetime warranty.
If your son only works with low voltages, then all this probably doesn't matter in the least...
