Author Topic: What type of plug is it ?  (Read 321 times)
Offline alex-shTopic starter
« on: August 14, 2024, 10:46:04 pm »
Hello all,
Silly question really but I cannot find any info.
Could you please help me to identify a type of DC plug?
Thanks
Offline jonovid
    • JONOVID
Re: What type of plug is it ?
« Reply #1 on: August 14, 2024, 10:58:38 pm »
a property plug & socket standard when most common plug & socket standards will not do the job.
deliberately made to be incompatible with common plug & socket standards.
Hobbyist with a basic knowledge of electronics
Offline themadhippy
« Reply #2 on: August 14, 2024, 11:23:18 pm »
Looks like the socket used on those wall warts  that come with 101 different plugs
« Reply #3 on: August 14, 2024, 11:42:20 pm »
You think this is a proprietary plug? However, it should still be possible to identify or find one?
« Reply #4 on: August 14, 2024, 11:43:05 pm »
No, it is not. This is a 24V DC power supply plug for a turntable.
« Reply #5 on: August 15, 2024, 12:26:27 pm »
I found it.
This plug is called “Texas plug”.
I hope it helps if anyone has the same question
