Author Topic: microphone tone control  (Read 8484 times)
Offline FlumpTopic starter
« on: October 07, 2013, 03:56:40 pm »
Hi all
I built this amp which works very well but i wanted adjustable
tone on it
http://www.electroniq.net/audio?page=50
so i built this bass and treble circuit
http://www.electronicecircuits.com/electronic-circuits/bass-treble-tone-control-circuit
and had mic - amp - tone but the bass and treble circuit
really attenuated the volume from the amp and the treble
didnt make much difference.
so i would like a simple tone (not bass and trebble)
that doesnt attenuate the amps signal.
can anyone suggest anything ?
Offline w2aew
    • My YouTube Channel
Re: microphone tone control
« Reply #1 on: October 07, 2013, 04:06:59 pm »
Hi all
tone on it
The preamp I did for the Astatic D104 mic might work for you. It offers bass and treble boost and cut.
FAE for Tektronix
Offline Valueduser
  • Put it on air
« Reply #2 on: October 07, 2013, 04:46:37 pm »
The tone circuit you linked to is always going to attenuate the signal given that it is a passive rc circuit.  One thing to try would be to put another amplification stage after the eq to boost the attenuated signal.
« Reply #3 on: October 07, 2013, 10:09:14 pm »
w2aew yours looks quite complicated for me not sure im up
to that standard yet.
Would yours work with different mic element types ?
im currently using a dynamic mic with 430ohm impedance
but would like to try electret elements too.
I wanted to build my amp into a project box
with in and out sockets so i could try different mics.
Thanks Valueduser i wasn't aware
that it would loose so much of the signal.
Offline Valueduser
  • Put it on air
« Reply #4 on: October 07, 2013, 10:56:40 pm »
What are you connecting the output of the amp to?  It's possible that there is an impedance issue causing the signal loss.
« Reply #5 on: October 08, 2013, 05:13:18 pm »
output of amp is going in to an amateur radio Valueduser
the original mic for the radio uses an electret element though
Offline w2aew
« Reply #6 on: October 08, 2013, 05:37:29 pm »
If you break it down, it really isn't that complicated.  More details are on this webpage:
 http://www.qsl.net/w2aew/myd104amp.html
It is basically the same tone-control circuit you showed, surrounded by two op amp stages (one is a preamp / impedance converter, and the other the buffer/gain stage around the tone control). Below the op amps in the schematic is simply the biasing network.  Lower right is the shunt-regulated power supply.  You could replace that with a 9V battery.  You can make the input single ended if you desired.  The output has some filtering to prevent RF from disrupting the circuit.  I've used this circuit on my amateur radio for more than 10 years.
FAE for Tektronix
Offline Paul Price
« Reply #7 on: October 08, 2013, 10:31:11 pm »
That 150K in the emitter of the preamp (titled Use with Crystal/Ceramic Heads", first transistor is way too big a resistor value to work..perhaps a typo, looks like should be 150ohm?
« Last Edit: October 08, 2013, 10:35:08 pm by Paul Price »
Offline w2aew
« Reply #8 on: October 09, 2013, 12:18:16 am »
Not a typo, that's the original design from Astatic, and it works perfectly well with the high impedance crystal element in the D-104 microphone. This mic/preamp combination was purposely designed 40+ years ago to provide audio with a treble-peaked response to aide in intelligibility under noisy conditions.
FAE for Tektronix
