I'm not sure how to approach finding the thevenin voltage and resistance with a bridge circuit. I'm trying to solve the circuit below:
![](https://dl.dropboxusercontent.com/u/91808950/ThevQ40.png)
The 2k2 is the load. I know the voltage at point B is 9V, but I can't figure out how to find the voltage at point A. Because the bridge is unbalanced I can't use resistor ratios. I also can't use series-parallel rules to collapse the resistances. I tried using voltage loops, ie. the rule that the total voltage in any given circuit loop should be zero, but that just gives me different voltage drops across the resistors depending on the loop I take.
How do I use thevenin with an unbalanced bridge circuit?
