All,
I am building a little project, it will be used in the automotive environment so I know there will be a lot of AC noise from the alternator.
The project will consist of several LED's, STM32F4 MCU, Can Transceiver, and FT232... Should be about 800-900ma of current draw.
My question is, would it be ok to use a LDO such as MIC39100-3.3WS with a wide input voltage range to step down from 13-14vDC to 3.3V for VCC with plenty of filter caps? I'm thinking i will have about 9w of dissipation, which I think is probably too much to dissipate with the pcb.
I am tight on space, is there a better switching solution with a small inductor?
Thanks
