Hi all,
I wonder if you can help me with this question:
The given impedances of the series LRC circuit are established at an angular frequency of 2000 rad/s.
Calculate the resonance angular frequency from the given circuit and calculate the current I through the inductor at resonance, given the voltage across the capacitor is 4j mV at resonance.
First, I think that the given impedances are when the frequency is 2000 rad/s , so I tried to find their values when the frequency is 2000 rad/s. Is the approach correct?
Then I remember the formula for finding the critical frequency was as how I wrote it in part 2 of answer. Any ideas if this is correct?
Also, I have no idea how to find the current across L at resonance. What I remember is that in resonance the impedance of C and L are canceling eachother so the given voltage should be the voltage same across the resistor. Can you check please?
