I'm troubleshooting a pedal circuit that is producing a lot of noise. I broke the circuit down (removed the actual function) to just the input jack connected to the output jack and am still getting the noise. As a reference, I run a 15 ft cable b/t a bass and a small amp. I hear some noise. but much less, at high volume.
On my breadboard, I have T -> T and S -> S wired between the input and output jacks. My bass goes into one jack using a 15ft cable (same as my reference). Coming off the breadboard, I have a 6ft cable. The wires between the jacks are about 5mm.
Is this expected from a breadboard set up?
Thanks,
Carl
