By the way, at 100% PWM that LC filter you provided shows a voltage spike before stabilizing. Is that something I should be concerned about? I'm not sure if ~20ms is long enough for such a spike to be dangerous.
EDIT 1: Changing the placement of the diode seems to cut off the spike as it should:
EDIT 2: Because I do not need the smoothing to be perfect I tried an LC filter with a smaller inductor. This actually seems to work quite well. The control curve is much better than an RC filter while also getting closer to 12V. The question remains:
is this a sane thing to do?I'm using a 1N5819 here because I have a few of those lying around. For the inductor values I used a 5900-222-RC (axial, 2.2mH, 1.7RDC, 500mA).
10% PWM: (this would be the lowest setting for practical use)
20% PWM:
30% PWM:
50% PWM:
100% PWM:
EDIT 3: This is probably a better way to do the flyback diode:
Having the diode in this configuration does raise the output voltage at low duty cycles: 10% PWM has gone from 3.3V to 5V.
EDIT 4: Added a resistor to the flyback diode to dampen the effect of the inductor during the off-portion of the PWM cycles. Mostly to improve the control curve, so I can have access to low voltages (3-4V) without resorting to ultra-low PWM duty cycles (<=5%).
Control curve now looks like this:
PWM% => Vout
5 => 1.3
6 => 1.7
7 => 2.1
8 => 2.6
9 => 3.0
10 => 3.5
11 => 3.9
12 => 4.3
13 => 4.7
14 => 5.1
15 => 5.5
16 => 5.9
17 => 6.2
18 => 6.5
19 => 6.8
20 => 7.0
25 => 8.2
30 => 9.0
35 => 9.6
40 => 10.0
50 => 10.6
60 => 11.0
80 => 11.3
100 => 11.8
