Author Topic: Wondering how to prevent this washer launcher from failing  (Read 817 times)
Offline wirehead_freenodeTopic starter
« on: January 05, 2021, 08:43:03 pm »
Hi, I have this circuit, it's basically an electromagnet which discharges capacitors into a coil. Works with high voltage.
The 25w/25Ohm resistor keeps failing and disconnecting. What kind of resistor should I use so that it doesn't fail?
Also, I run it at 1 pulse every 20 seconds. The coil runs cool.
« Last Edit: January 05, 2021, 08:44:55 pm by wirehead_freenode »
Offline srb1954
  • Retired Electronics Design Engineer
Re: Wondering how to prevent this washer launcher from failing
« Reply #1 on: January 06, 2021, 06:15:33 am »
If you don't have the knowledge to work this one out yourself you shouldn't be playing with such dangerous circuitry. You should take the time to learn some basic electrical theory and maybe then you will realise how much risk you are taking.
You also don't seem to have taken any notice of the safety advice offered in the response to your previous post regarding this circuit.
Offline Gyro
« Reply #2 on: January 06, 2021, 10:15:21 am »
Which is it? A washer launcher or a PEMF machine?
https://www.eevblog.com/forum/dodgy-technology/wondering-what-the-voltage-on-this-pemf-machine-is/
It's not safe for a beginner to be playing with either way.
Best Regards, Chris
