Yeah thanks for the compliment... ![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
Care to upload an awesome drawing of yours?
Well, the way you draw a circuit is important for being able to recognize the parts. How's this? Now you can see all the RC relationships and the signal path - the signal charges C4 through R3->D4A, discharges C4 through R72, is pulled up by R1 in the absence of a signal input, and is clamped to VDD by D4B.
Excuse the wrong diode symbol and the wrong name for the rail... (Edit: fixed)
If I were drawing this into a full, proper schematic, I'd go one step further and annotate it with the voltage thresholds and the expressions for the delay constants.
Also, for noise immunity (and depending on how well the power rail is decoupled), I'd reroute C4 to ground instead of VDD. Won't make a difference at all in operation. Otherwise you're AC-coupling any power supply noise into the signal. Of course, a Schmitt inverter won't be too susceptible to that.
