The visual inspection are good as indication, up to a point.
It could even become a trap , if it is not combined with true knowledge, about the circuitry that you deal with.
The common usual mistake , are to blindly exchange damaged looking parts,
and the true fault to be actually else-ware,
the upcome are that new parts will fail too.
Thats why the old Greek freelancers technicians (80s) , they was had as standard 24 hours continuous testing, before one repair considered as an successful one.
At 90s we had full documentation about most devices , voltage check points & oscilloscope curves check points .... was our weapons to be more productive , and minimize the testing period.
In our times , industry managed to turn us as totally blind ones.
And up to this point , I would say , that I call as "expert" troubleshooter, the one who has manage to repair things , with the use of less sophisticated diagnostic methods + instinct + determination.
