Here are some my random thoughts about experiences with audio stuff:
I hate when audio marketing people explain something using engineering terms, without having any facts supporting their statement. I often tend to say that something may sound different without having any difference on the signal at all. Why not leave it just that way. I mean something like
this. Anybody with a calculator can easily calculate the impedance of the RCA connector; it is near 30-40 ohms, not the mentioned 200 ohms! That makes RCA a poor choice at video or coaxial SPDIF interfaces.
Cable parasitic properties matter because way the audio interfaces are made, relatively high output impedance causes quite easily roll-off near 20 kHz. That brings me another question, why not make output impedance 50 ohms and terminate the inputs too to 50 ohms. That way one could get several GHz of bandwidth practically for free (or not free, one would have to use decent connectors, RCA's are a mechanically a joke compared to SMA or even BNC). Thus it would make the parasitics irrelevant, instead they become an essential part of the system.
I'm not sure that SPDIF is any better than USB. The fact that DAC master clock has to be recovered from possibly bad signal for both USB and SPDIF may in fact lead to measurable differences in the DAC clock phase noise (or jitter). You can think that as a frequency modulation of your sampled data. Clock timing is always essentially analog variable and it suffers easily. It is easy to get zeros and ones correctly but getting them exactly at right time is not so easy. The timing issue is completely irrelevant for computer storage media, as long as zeros and ones come through correctly. It would be technically much better if the receiver (DAC) would clock the source. That way the critical master clock would not have to be recovered via PLL from incoming data stream. I once measured SPDIF output from my DVD-player and it
looked quite horrible. Bounces and rings. That measurement is not surprise when I looked inside, SPDIF is routed through large single-sided PCB. It made a signal integrity engineer in me to cry.
For some years ago, I designed and built
DAC-headphone amplifier combo (TI TPA6120A2 as an output amplifier/buffer), using Jung super regulators in the power supply. I don't think that super regulators really made the difference, but hey, why not. At least they have measurable much less output noise and lower output impedance than common jellybeans, like 78/79xx or 317/337. As I write this text, I'm listening this thing. Sounds still nice.
My another audio experience was the rebuild of my Tripath(rip)-based amplifier. That thing was riddled by hilarious amounts of EMI noise and stability problems. The ground system was done exactly like Tripath recommended, separate grounds for power and signal, connecting them to the TA0104 module corresponding pins. After the amplifier destroyed itself with somekind of spurious oscillation, I decided to design a new PCB just against the manufacturer recommendations, I used a
multilayer PCB (yes, it has SMA connectors as audio inputs!) with single solid ground layer in it. This has been proven to be successful approach at my work in countless EMC testing situations. The result was that not only the EMI and stability problems were gone, but the amplifier is much more silent than before. My conclusion is that RF-approach seems often work best, even at low frequencies. Although the circuit itself operates at relatively low frequencies, the noise in the environment may be high frequency stuff. My friend also rebuilt his amplifier and got similar results. I wonder why Tripath didn't mention this approach in their application notes
Regards,
Janne
