Ok,
let's look at the following two transistors, the Fairchild KSP42/43 and the Fairchild KSP13/14. First, the datasheets:
KSP42/43KSP/13/14The first is a "high" voltage NPN, and the second is a Darlington. The first has a collector current of 500mA and the second also 500mA.
The 42/43 has an hFE of 25 @ Vce=10V & Ic=1mA=10V ----- an Hfe of 40 @ Vce=10V & Ic=10mA ------ and finally an Hfe of 40 @ Vce=10V & Ic = 30mA.
I thought that hFE Gain was the amount of times that the current you put through the Base is "amplified", or if I put 1mA on the Base, I get 40mA say on the Collector current.
But, if the gain is 40 @ 30mA, isn't that a total of 1.2Amp? or 1200mA? Doesn't that exceed the 500mA of the collector?
The KSP 13/14 has hFE from 5K - 20K, due to it being a Darlington?
So what am I missing or not understanding? And also, what voltage do I have to put to the Base to get the transistor to "turn on"? Or does it not matter as long as I have a minimum current? Where do I look @ the datasheet for that info?
If it says Emitter-Base voltage is 10V, does that mean that maximum base voltage I can input is 10V? Irrespective of current?
Thanks in advance
