The front panel pwr on/off push button has an "idiot" green LED light that indicates three conds:
ON (solid) -- on with signal (CRT should display input signal or monitor-generated menu)
ON (blinks) -- on with no input signal (CRT should display monitor-generated menu or scrolling "NO INPUT SIGNAL" text message)
OFF (unlight) -- pwr off (main pwr push-button in out position), or no pwr (unplugged, damage, etc.)
I have solid on pwr button LED, but no CRT image -- not even Samsung's own internal-generated menu. Powering switch OFF and re-powering, I get the usual 2-3 sec delay and then the pwr LED turns ON.
All the ICs I can stick my probe on seem to be getting clean 5VDC. But the normal "bang" of the HV section does not happen. Dunno whether HV is bad or whether HV isn't getting signal to turn on.
What's weird is the solid pwr button LED, noted above. It should blink if there is no input connected. But it is solid regardless of the presence of input.
Any quick ideas?
Thx!!
