Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Pic input/output pins
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Pic input/output pins (Read 2748 times)
Zedy
Contributor
on:
June 24, 2010, 11:56:58 am »
hi!
Just started a project, and have some question, if I make TRISC ('b'00001111), and try to write(for example):
movlw 0xFF
mowf PORTC
what will happen? will the input pins ignore this, because they are inputs?
Logged
Strube09
Regular Contributor
Country:
Re: Pic input/output pins
Reply #1 on:
June 24, 2010, 03:08:24 pm »
For PIC, when you set the pin as an input you disable the output driver for that pin. So writing to the port(x) pin will not affect the pin.
However I do believe that if you change the pin back to an output it will then display whatever your last write to the port(x) register was. So be sure to set the pins to a default or safe position before enabling any pin as an output.
Logged
Zedy
Contributor
Reply #2 on:
June 24, 2010, 06:54:07 pm »
Thanks for help
about pull-up -> referring to datasheet OPTION Register controls pull-ups
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
