Author Topic: Troubles programming Rigol DS1102CD with Labview  (Read 4244 times)
Offline nekromendisTopic starter
« on: June 21, 2010, 10:02:41 pm »
I am trying to programm a Rigol Scope DS1102CD with firmware version 03.03.01 using Labview 8.6. I install the last version of VISA however the USB resource is not detectable by MAX it is only detectable when I generate the driver with Driver Wizard but the programm does not work setting USB RAW I supose should be USB INSTR. Someone could help me?
I download the Rigol example using Labview but it doesnt work USB can not be detectable
Could be the firmware version?
