Author Topic: Excel count no of words occurs in column  (Read 844 times)
Offline Vindhyachal.taknikiTopic starter
« on: July 09, 2022, 06:37:16 am »
1. I have excel column as below:
2. Need to show in excel how many times each individual word appears like
One: 2
Two: 2
Three: 1
Five: 2
3. How to do it?
Online Ian.M
Re: Excel count no of words occurs in column
« Reply #1 on: July 09, 2022, 09:30:58 am »
*One* way of doing it is like this.
How it works:
In the column uniques apart from the first line (which is just the data value), there is a MATCH function that checks if the data value is found anywhere above that line (note the slightly tricky array reference with the first row absolute).   If not, it will return error value N/A.  The IFNA function tests for that error value, and either returns the data or an empty string.
In the column count, if  uniques is non-blank not an empty string, it uses the COUNTIF function to count the number of occurrences of it within the data
« Last Edit: July 09, 2022, 01:38:54 pm by Ian.M »
Offline mariush
« Reply #2 on: July 09, 2022, 12:58:03 pm »
If the number of words is very small, you could have a vertical column for each possible word somewhere far to the right where you put 1 or 0 if the cell has that word
ex  =IF(A2="One",1,0)
Then you can have a summary
One  |  =SUM(J1:K100)
Two | = SUM(K1:K100)
Three | = SUM(K1:L100)
.. and so on
« Last Edit: July 09, 2022, 01:01:42 pm by mariush »
Online PA0PBZ
« Reply #3 on: July 09, 2022, 01:12:03 pm »
The following users thanked this post: eugene
« Reply #4 on: July 10, 2022, 06:04:01 am »
there are around 500 such words in a column, which may or may not be repeat.
Checking for individual would be diffcult.
Is there no such formula which can count each unique word?
Online PA0PBZ
« Reply #5 on: July 10, 2022, 08:38:45 am »
After applying the formula you can convert the formulas into values (In the example above right click column B, Copy, Paste as values) and then select column A and B and remove duplicates (on the Data menu). That will leave you with a single row for each value (word).
Offline geggi1
« Reply #6 on: July 10, 2022, 11:15:45 am »
the simplest way is to use the COUNTIF function.
Here is a quick tutorial. https://www.w3schools.com/excel/excel_countif.php
I use this function a lot in my spreadsheets.
Online Ian.M
« Reply #7 on: July 10, 2022, 02:01:33 pm »
Yes. That's what I did back in reply #1.   The problem is to auto-populate the list of unique words, which I did by determining if the word did not appear on any line above it, which gave me the unique word next to its first occurrence, with its count next to that.  If you need to eliminate the blank lines, you could try filtering on the unique word being not "".
