i find the hydrogen peroxide and acid mix works well but very slow when used a few times,but heating it up in the microwave helps speed it up,hence the original queston as most cleaners are heated,i need to try it in my ultrasonic cleaner and see,need to float a container in the cleaners fluid holding the pcb to be etched tho as i guess the acid mix would eat the stainless cleaner tank.
