1) While I have several cheap tin/lead leaded solder and lead free solder I am looking for some good quality replacements.
2) More importantly, I am looking for a better flux that the ones I currently use.
My current flux options
![](https://i.postimg.cc/Xv6FDf2d/20200724-070830.jpg)
The bottled Flux
The flux in the bottle is very good but it leaves a very stick mess behind it. Obviously this can be cleaned with alcohol but it makes the process longer an messy and not very practical when doing a lot of joints. I would prefer a flux that I could use that is easier and leaves not residue.
The Pen flux
The pen flux is the other end of the scale as it leaves little residue but does not do such a good job.
I guess I am looking for something in between of great quality!
So please feel free to recommend some decent leaded solder, Lead free solder, Flux.
Cheers ![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
hi
the best flux for lead free which i use from long time is SYNTECH-LF-TF genuine from amtech company , is goog for smd solder also reballing and is almost heavy-odour less because is syntetic , amtech have also lf-4300 for lead-free/leadded solder and NC-560 for lead free , but from my opinion and experiments i can say i cannot solder correctly all lead-free balls on large bga this water washable flux almost evaporate untill every ball flow to pad position , as about NC-560-LF i cannot completly solder lead-free balls
SYNTECH-LF-TF - works very good with lead-free solder and did not evaporate untill bga balls flow to its position , heavy odour-less nice smell because is syntetic
this flux is also manufactured by CHIPQUIK company and is only usefull for lead-free solder
LF-4300 water washable flux also almost odourless but it is usefull from my opinion only for leadded solder with lead-free it too fast evaporate
NC-560-LF - no good for bga maybe for smd ive never place any balls on cpu correctly - it is irritant when inhalle !!!
from my opinion for lead free solder you need flux which will keept you temperature more longer than usuall flux for sn60/40 leadded , it should be dedicated for lead-free solder only like syntech-lf-tf
