Author Topic: Which HP Badge indicates the newer model?  (Read 2146 times)
Offline ReprobyteTopic starter
« on: June 15, 2018, 02:06:53 am »
I own HP equipment and also I see used HP equipment online, same model numbers and the same looks but different badges
My own assumption is the monochrome one is newer than the blue as I have 70s gear with the blue
Can anyone shed light on this?
Offline bitseeker
Re: Which HP Badge indicates the newer model?
« Reply #1 on: June 15, 2018, 04:32:24 am »
I have HP gear from the 70's through the 90's with badges. The blue and black badge tends to be from the earlier decades and the monochrome one from the later ones. So, yes, the monochrome one is often newer, but there's a significant overlap in the overall chronology (i.e., there doesn't seem to have been a global switch from one badge style to the next). For a particular device model, though, it's probably OK to use the generalization.
Prior to the 70's everything I have has the logo either printed on or etched/engraved/stamped into the panel.
« Last Edit: June 15, 2018, 04:34:22 am by bitseeker »
Offline bitseeker
« Reply #3 on: June 15, 2018, 06:13:36 pm »
Thanks, Tomorokoshi. Those are very interesting. The May 2000 issue has the most complete summary of design changes.
The horizontal blue/black badge that was used during the 70's and 80's is probably a color version of the 1968 logo. The frame on the badge would match the rule element in the printed logo.
The monochome badge would then be a version of the 1979/1999 logo with its rounded corners.
« Reply #4 on: June 16, 2018, 12:07:16 am »
Very interesting, thanks for the info on this! Wonder if you can buy them for gear with the missing badge
Offline bitseeker
« Reply #5 on: June 16, 2018, 01:29:21 am »
I haven't run into a source for the badges. It'd be nice, though.
Offline Tomorokoshi
Offline bitseeker
« Reply #7 on: June 17, 2018, 03:53:37 am »
Thanks, Tomorokoshi. That's the first time I've seen them available for sale. $5 a piece, though. ???
Offline bitseeker
« Reply #9 on: July 02, 2018, 12:22:18 am »
Sorry to hear that, Reprobyte. I thought I saw that there were a couple left before the end date, but the listing hasn't come back up. Maybe message the seller, just in case.
« Reply #10 on: July 03, 2018, 02:41:37 am »
I should have checked the forum  ::)
Anyways thanks I have messaged him! :)
