Yeah transformer phasing is backwards. Take a close look at the dots on the windings! Double check the transformer datasheet as well.
VD doesn't have a ground reference to the connector, and is mains referenced, as mentioned. Better to just not do it at all. If you're doing like nixies or something, better to use a secondary side boost/flyback, yes, more stages, who cares, it's low power.
C? is way too large, I... oh, no designators. The 22nF GND-GND one. Too much ground leakage.
L? 10uF is pretty large, probably doesn't matter but 1uH would be enough. Depending on what you're running, it might not be needed at all (and the second cap).
The 0.1 compensation cap may want a resistor in series. Even if you don't end up using it (0-ohm jumper), good to have the option.
Cheers!
