Author Topic: Digital Chirp signal BW  (Read 116 times)
Offline mr_byte31Topic starter
« on: July 19, 2024, 05:35:21 pm »
Hi Folks,
I have a pulsed signal and I would like to measure the BW of the high power frequencies in it as shown in figure below. The shortest pulse shall be in 100 us.
I will build a circuit and will use a microcontroller for that.
The signal looks like a chirp signal but somehow in digital fashion with DC offset. I can see the frequency of the signal increase with time so I called it digital chirp signal. I don't know if it has a scientific name or not !
I thought of the following techniques:
  • collect samples via ADC and use FFT to figure out the high power frequencies and measure the BW.
  • use pulse discriminator to figure out the positive edges and measure the time between them
  • use zero crossing circuit and measure the time as point above
  • use PLL and measure the voltage before the VCO to figure out the frequency ranges
is there a simpler or more recommended solution for such problem statement ?
« Last Edit: July 19, 2024, 05:37:04 pm by mr_byte31 »
Online radiolistener
  • Country: ua
Re: Digital Chirp signal BW
« Reply #1 on: July 19, 2024, 06:07:32 pm »
You can measure rise or fall time (which is more fast) with oscilloscope and then calculate bandwidth:
BW_MHz = 350 / rise_time_ns
But oscilloscope needs to have high enough bandwidth, otherwise oscilloscope bandwidth will limit your measurements.
The following users thanked this post: mr_byte31
