Author Topic: Please identify this Hall-Sensor-Chip  (Read 2131 times)
Offline HighVoltageTopic starter
« on: October 13, 2014, 10:46:23 am »
I am looking for a datasheet of the Hall-Sensor chip in these pictures.
The numbers to don't come up in google.
May be someone has used this sensor before and give a hint of who the manufacturer is?
Thanks.
Offline kolbep
    • ShoutingElectronics.com
Re: Please identify this Hall-Sensor-Chip
« Reply #1 on: October 13, 2014, 08:32:11 pm »
If that is a qr barcode silkscreened on the back of the device,
then scanning it with a qr  barcode app on your phone may reveal a manufacturer
www.ShoutingElectronics.com Don't just talk about Electronics, SHOUT ABOUT IT! Electronics Blog Site and Youtube Channel
Offline Rudane
    • Electrical Engineering 101
« Reply #2 on: October 14, 2014, 12:52:11 am »
Looks like a Chinese made one. http://item.taobao.com/item.htm?id=18546230854.
You'll have to contact them for the datasheet. It will likely be in Chinese. I use Google translate to translate the datasheet. It's a pain.
Voltage appears across and current flows through.
« Reply #3 on: October 14, 2014, 07:47:37 am »
@kolbep
The barcode did not reveal any useful information
@Rudane
Thanks so much for the link.
I will see, if they have an English datasheet or if they even speak English by email.
It is a good start, thanks again
« Reply #4 on: October 15, 2014, 08:22:55 am »
I found the original manufacturer.
Infineon
Part Number: TLE4983C-HT E6747
Problem solved.
Thanks for all your help and input.
BTW, this is not a typical Hall Sensor, as I expected...
It is a Programmable True power on sensor
Features:
- TPO True Power On functionality
- Increased BTPO range
- Mono-cell chopped Hall system
- TIM Twisted Independent Mounting
- Dynamic self-calibrating algorithm
- End-of-line programm able switching points
- TC of back-bias magnet programmable
- High sensitivity and high stability of the magnetic switching points
- High resistance to mechanical stress
- Digital output signal (voltage interface)
- Short-circuit protection
- Module style package with two 4.7/47 nF integrated capacitors
- Package: PG-SSO-3-91 with nickel plating
Datasheet enclosed
« Last Edit: October 15, 2014, 08:37:09 am by HighVoltage »
