So I was interested in making a low noise dc power supply. I came across the following website:
http://www.wenzel.com/documents/finesse.htmlI built a linear regulator on a breadboard with the following configuration:
12-0-12 Transformer > Diode Bridge (with 2200uF smoothing) > LM317 voltage regulator (with 10uF/100n on output, 10uF on adjust, 100n on input + protection diodes) > figure 3 from the website.
I used a LT1001 as a replacement for the LM883 and a 2n2222 instead of a 2n4401 and I used a 100 ohm 26 turn trimpot as a replacement for the 15 ohm resistor (for trimming). Bourns brand.
Is this type of circuit testable on a breadboard, with such low noise levels?
When I measure it the LM317 output gives me a noise reading of 0.002mV rms while the output of the wenzel shunt is 0.003mV rms, which is slightly worse. Measurements made by a agilent 34401a.
Is the lt1001 responsible for this? The slew rate and gbp are 1/20th of the lm833, a direct contradiction to the recommendations given on the wenzel website.. I do not have any large bandwidth high slew rate amplifiers so I decided to just throw it together using "inappropriate parts" for fun (lol new years!).
I have a more suitable op-amp coming in the mail but do you think there will be a detectable difference between the output and input on a breadboard? Or must circuits of this type be soldered with solid ground planes before they work?
Or is the transistor replacement choice inappropriate? I am not sure what transistor parameters are important for this type of circuit. I tried a s9018 with little difference.
I never experimented with low-noise circuitry so any tips are appreciated.
