I have several questions for someone a lot smarter than me... I am trying to put together a parts list for this power supply, and I want to order everything I need to finish it at once, first is the bridge rectifier, it calls for a 6 amp 200 volt PIV bridge rectifier. The only ones I have found with those values are for PCB mounting, not chassis mounting. Later on it calls for a 0.1uF Ceramic Disk capacitor, but gives no value for voltage... HELP please
C3 and C4 are the caps I was talking about in this schematic, the other image is a overall schematic
