Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
How to power a Nixie tube?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: How to power a Nixie tube? (Read 3414 times)
Azhar
Regular Contributor
Country:
on:
July 06, 2013, 10:28:13 am »
Do we need to build a circuit to light up a Nixie tube? or we can do it with just a power source?
Logged
amyk
Super Contributor
Re: How to power a Nixie tube?
Reply #1 on:
July 06, 2013, 10:57:05 am »
Depends how you want to light it up...
Logged
Azhar
Regular Contributor
Country:
Reply #2 on:
July 06, 2013, 11:15:09 am »
I have a ten digit Nixie tube, and wanted to light up the digits one by one! is that possible by applying voltage directly to it?
Logged
Psi
Super Contributor
Country:
Reply #3 on:
July 06, 2013, 11:24:34 am »
You could just have 10 switches but you need a high voltage source.
Just how high a voltage depends on the nixie tube you have.
Last Edit: July 06, 2013, 11:26:37 am by Psi
Logged
Azhar
Regular Contributor
Country:
Reply #4 on:
July 06, 2013, 11:29:44 am »
Does that mean, they work normally like any LED display? I don't need another power source to heat a filament for example?
Logged
Paul Price
Super Contributor
Reply #5 on:
July 06, 2013, 11:43:09 am »
The Nixies require a low-current, Usually unregulated, approx 140V to 170V (depending on the Nixie type)power source connected to a common anode and a current limiting resistor is connected to each numerical or other symbol display cathode pin. The other side of the current limiting resistor connects to the collector of a HV small transistor that is turned on and off at logic level voltages with a resistor to its base, and the emitter of the Nixie driver transistor connects to ground.
Sometimes a small pot-core transformer is used with a oscillator circuit to generate a 140V source from a logic level power supply voltage.
for more info,
http://en.wikipedia.org/wiki/Nixie_tube
Last Edit: July 06, 2013, 11:50:30 am by Paul Price
Logged
Azhar
Regular Contributor
Country:
Reply #6 on:
July 06, 2013, 01:31:02 pm »
Thanks a lot! thank you all
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
