Thanks for the all answers. I will try to answer all.
My preamp will be inside of the microphone. I am tryin' to learn. I want to do more hands-on projects to see the real life. I will first simulate and then print the PCB.
The phantom power comes from scarlett. It is P48.
I understand that if I take the 48V from XLR's 2.pin for FDOpamps' positive and 3.pin for FDO's negative, then that circuit will work. I hope I understand it right.
I will connect the earthing to XLR's 1.pin. This will be the RF caps. I will also put small ceramic caps between 1-2 and 1-3.
